[GRASS-dev] [GRASS GIS] #2740: v.in.ogr: wrong projection check when importing geometry column from table with multiple geometry columns
trac at osgeo.org
Fri Sep 11 09:34:07 PDT 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Vector | Version: svn-trunk
Keywords: v.in.ogr geometry columns | CPU: Unspecified
Platform: Unspecified |
r63604 introduced the possibility to import from data sources with
multiple geometry columns (gdal RFC41).
However, AFAIU, the projection check has not been changed and so the
projection is gotten from the layer, not the field (aka geometry column).
It seems to me that the gathering of information concerning the geometry
column in
[http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.in.ogr/main.c#L870
lines 870ff of main.c] needs to be moved higher up to before getting the
projection
([http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.in.ogr/main.c#L543
lines 543ff]), so that the projection can be gotten from the '''geometry
column''' and not from the layer.
But I'm not 100% sure of understanding the code correctly, so this needs
confirmation.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2740>
