[GRASS-dev] addon mismatch
Vaclav Petras
wenzeslaus at gmail.com
Fri Sep 11 10:44:04 PDT 2015
On Fri, Sep 11, 2015 at 1:37 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> On 11-09-15 19:31, Vaclav Petras wrote:
> On Fri, Sep 11, 2015 at 1:13 PM, Paulo van Breugel <
> <p.vanbreugel at gmail.com>p.vanbreugel at gmail.com> wrote:
>> PS: no idea what "WARNING: No addons metadata available. Addons
>> metadata file not updated." means
>> No clue either, but maybe the reason it doesn't show in the g.extension
>> GUI?
> Well, I did pretty heavy changes in trunk's g.extension but I was not
> getting this warning. It means that it can't find a particular XML on the
> server. Does this happen for other addons or just r.biodiversity?
> It seems not, I just tried to (re) install two others (r.bioclim and
> r.mess) and I did not get such warning
I don't know if the server-side XMLs are generated for 71 or just 70 but
probably they are. Then I can also see that the addons page [1] data in the
bottom is some completely old one (Út srp 18 means Tuesday, August 18).
Since it is happening just for the new addon, it might be just because of
some delay in generating all server side things; I always have the feeling
that there is some delay, although it should be just 24 max.
[1] https://grass.osgeo.org/grass70/manuals/addons/
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150911/dfdd987d/attachment.html>
