[GRASS-dev] [GRASS GIS] #2065: grass70 not detecting latest source build of libLAS (1.7.0)
GRASS GIS trac at osgeo.org
Mon Sep 14 17:28:57 PDT 2015
  Reporter:  rashadkm   |      Owner:  grass-dev@…
      Type:  defect     |     Status:  closed
  Priority:  normal     |  Milestone:  7.1.0
 Component:  Compiling  |    Version:  svn-trunk
Resolution:  fixed      |   Keywords:  liblas
       CPU:  All        |   Platform:  Linux
Comment (by wenzeslaus):
 Replying to [comment:9 jmburgos]:
 > Same problem bulding grass 7.0.0. On CentOS 7, with
 liblas-1.8.0-3.el7.x86_64 and liblas-devel-1.8.0-3.el7.x86_64 already
 installed.
 Please be more specific and provide the error messages and logs. Also
 please report what running `liblas-config` with various parameters gives
 you. I don't know what to check in the source code since I can't reproduce
 the issue myself. Several people reported "same problem" but the ticket
 contains two different issues. One with includes (that's the //file not
 found// or //dir doesn't exist// error), one with linking libraries
 (that's the //undefined reference...collect2: error: ld// one).
 Good thing to try would be to make a Dockerfile which can be shared and
 fixed. See e.g. https://github.com/wenzeslaus/grass-gis-docker.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2065#comment:10>
