[GRASS-dev] all categories copied over to new map
Paulo van Breugel p.vanbreugel at gmail.com
Wed Sep 16 01:48:34 PDT 2015
On 16-09-15 09:49, Moritz Lennert wrote:
> On 15/09/15 20:08, Paulo van Breugel wrote:
>> Suppose I have a categorical raster map and I want to 'cut out' a subset
>> (with g.region to set a small region and r.mapcalc to create the new
>> map). This map has a smaller number of categories, as is shown using
>> e.g., r.category. However, when plotting the legend, all the categories
>> of the original map are included in the legend. Checking the 'cats' file
>> shows that it indeed lists all original categories and labels, including
>> for those categories not present in the new map. This doesn't make sense
>> to me, but perhaps I am missing something here?
> AFAIK, the legend is determined by the color table, and the color
> table is probably just copied as is from the input to the output map.
> You can check with r.colors.out. If you redefine a color table with
> only the relevant categories, then the legend should reflect that.
Hi Moritz, that is what I thought, and as the whole color table does
indeed get copied over, I wrote a small script to remove the 'redundant
color definitions. However, that did not help, the whole 'old' legend is
still showing.  I had missed that -n flag, so I'll give that a try. Is
there a similar option in ps.map to omit categories without label?
 From a more conceptual point of view, is there any reason the whole
category table is copied over to the new cats file?
> You could also try d.legend with the -n flag to only show categories
> which have a label.
> Moritz
