[GRASS-dev] [GRASS GIS] #2744: r.import latlong bug
GRASS GIS trac at osgeo.org
Thu Sep 17 08:02:26 PDT 2015
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.1.0
 Component:  Python       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.import
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [ticket:2744 neteler]:
 > Would it be possible to catch this user error?
 why is this a user error ? r/v.import are supposed to allow importing data
 that is in one projection into a location in another projection.
 > The user tried to import reprojected METOP-A data (Stereographic
 projection) into a LatLong location (yeah, things happen):
 > r.import input=EUMETSAT/output/Soil
 moisture/1/ascat_METOPA.20090401163331.12715_soil_moisture.tif
 output=01_third
 > WARNING: Datum <unknown> not recognised by GRASS and no parameters found
 > Proceeding with import of 1 raster bands...
 > Importing raster map <01_third>...
 > Traceback (most recent call last):
 >   File "/usr/local/grass-7.1.svn/scripts/r.import", line
 > 333, in <module>
 >     sys.exit(main())
 > 258, in main
 >     srcregion = grass.parse_key_val(tgtextents,
 > val_type=float, vsep=' ')
 >   File
 > "/usr/local/grass-7.1.svn/etc/python/grass/script/utils.py",
 > line 223, in parse_key_val
 >     result[k] = val_type(v)
 > ValueError: invalid literal for float(): 53:39:06.894826N
 As mentioned on the ML (sorry, I didn't notice this was a ticket, need
 more sleep):
 parse_key_val has an optional parameter val_type which is set to 'float',
 here, but r.proj outputs lat-lon coordinates in DMS style. I don't know
 why val_type is set here and if that is necessary as the results are just
 sent to g.region which can take strings as input.
 So as first try I would just delete this parameter from the parse_key_val
 call and see what happens.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744#comment:1>
