[GRASS-dev] [GRASS GIS] #2746: GUI fails to start: wx3.0 issue ?
GRASS GIS trac at osgeo.org
Thu Sep 17 08:34:28 PDT 2015
 Reporter:  mlennert     |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  critical     |  Milestone:  7.0.2
Component:  wxGUI        |    Version:  svn-releasebranch70
 Keywords:  g.gui wxgui  |        CPU:  Unspecified
 Platform:  Linux        |
 With a freshly checked out grass70_release, I get the following error when
 trying to launch the wxGUI:
 ATTENTION : le chargement de certaines extensions à échoué. Merci de
 mettre à jour vos extensions en lançant 'g.extension.all -f'.
   File "/data/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-unknown-
 linux-gnu/gui/wxpython/wxgui.py", line 142, in <module>
     sys.exit(main())
 linux-gnu/gui/wxpython/wxgui.py", line 134, in main
     app = GMApp(workspaceFile)
 linux-gnu/gui/wxpython/wxgui.py", line 49, in __init__
     wx.App.__init__(self, False)
   File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py", line
 8628, in __init__
     self._BootstrapApp()
 8196, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
 linux-gnu/gui/wxpython/wxgui.py", line 83, in OnInit
     workspace = self.workspaceFile)
 linux-gnu/gui/wxpython/lmgr/frame.py", line 132, in __init__
     self._createMenuBar()
 linux-gnu/gui/wxpython/lmgr/frame.py", line 252, in _createMenuBar
     self.menubar = Menu(parent=self,
 model=self._menuTreeBuilder.GetModel(separators=True))
 linux-gnu/gui/wxpython/gui_core/menu.py", line 44, in __init__
     self.Append(self._createMenu(child), child.label)
 linux-gnu/gui/wxpython/gui_core/menu.py", line 52, in _createMenu
     subMenu = self._createMenu(child)
 linux-gnu/gui/wxpython/gui_core/menu.py", line 58, in _createMenu
     self._createMenuItem(menu, label=child.label, **data)
 linux-gnu/gui/wxpython/gui_core/menu.py", line 99, in _createMenuItem
     rhandler = eval('self.parent.' + handler)
   File "<string>", line 1, in <module>
 AttributeError: 'GMFrame' object has no attribute 'OnTplotTool'
 Error in atexit._run_exitfuncs:
   File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
     func(*targs, **kargs)
 PyAssertionError: C++ assertion "GetEventHandler() == this" failed at
 ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event
 handlers must have been removed
 Error in sys.exitfunc:
 wx._core.PyAssertionError: C++ assertion "GetEventHandler() == this"
 failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed
 event handlers must have been removed
 Build and library info:
  ./configure  --prefix=/usr/lib --sysconfdir=/etc --sharedstatedir=/var
 --enable-socket --enable-shared --enable-largefile --with-postgres --with-
 mysql --with-pthread --with-cxx --with-x --with-gdal --with-freetype
 --with-motif --with-readline --with-nls --with-odbc --with-sqlite --with-
 freetype-includes=/usr/include/freetype2 --with-tcltk-
 includes=/usr/include/tcl --with-postgres-includes=/usr/include/postgresql
 --with-mysql-includes=/usr/include/mysql --with-proj-share=/usr/share/proj
 --with-python=/usr/bin/python-config --with-cairo --with-geos --with-blas
 --with-lapack --with-liblas=/usr/bin/liblas-config
 libgis Revision: 64733
 libgis Date: 2015-02-25 01:56:29 +0100 (mer 25 fév 2015)
 PROJ.4: 4.9.1
 GDAL/OGR: 1.11.2
 GEOS: 3.5.0
 SQLite: 3.8.11.1
 wx: 3.0.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/2746>
