[GRASS-dev] [GRASS GIS] #2749: Integrate 'Change mapset' dialog in manager toolbar
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Sep 18 06:53:14 PDT 2015
> Reporter: mwortmann | Owner: grass-dev@…
> Type: enhancement | Status: new
> Priority: normal | Milestone: 7.1.0
> Component: wxGUI | Version: unspecified
> Resolution: | Keywords: mapset, toolbars, layer manager
> CPU: Unspecified | Platform: Unspecified
> Comment (by annakrat):
> Replying to [ticket:2749 mwortmann]:
> > Wouldn't the simple (Settings > GRASS working environment > ) Change
> mapset dialog be a lot more useful in the Layer Manager toolbar? I'm not
> sure how many people are actually using the dialog, but I'm sure most use
> the commandline to do this simple change. I
> I use the dialog quite often when I don't remember the mapset names.
+1 I use it a lot as well
> >always thought typing 'g.mapset xyz' (plus maybe g.mapset -l) or going to
> the dialog, seems too much for such a simple thing. The simple dropdown
> without the Ok button would be quick and easy. Plus it could show the
> current mapset which is somewhat missing in the Layer Manager.
> I mostly agree but I am not sure where to put it, there is already a lot
> of things in the toolbar, so we would have to start a new row of toolbars?
> Maybe the data catalog tab would be an option?
I think the number of buttons is fairly limited, one more wouldn't be a
problem i.m.h.o. But a context menu when right clicking on a map set in
the data catalog, with the option to change to that map set may even be
better,
> BTW, on Ubuntu, you can type Alt and then 'Change ...' and launch the
> dialog in this way, too.
I totally forgot about that, thanks for the reminder :-)
> Ticket URL: <https://trac.osgeo.org/grass/ticket/2749#comment:1>
> GRASS GIS <https://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
