[GRASS-dev] table with the parser standard options
Luca Delucchi
lucadeluge at gmail.com
Sat Sep 19 01:51:43 PDT 2015
Il 19/set/2015 10:42, "Martin Landa" <landa.martin at gmail.com> ha scritto:
> Hi Luca,
Hi Martin,
> thanks, unfortunately travis has problem with that
> GISBASE="/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu"
> ARCH="x86_64-pc-linux-gnu"
ARCH_DISTDIR="/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu"
> VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python
> ./parser_standard_options.py -t ../lib/gis/parser_standard_options.c
> -f grass -o
/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html
> -p 'id="opts_table" class="scroolTable"'
> Traceback (most recent call last):
> File "./parser_standard_options.py", line 157, in <module>
> args = parser.parse_args()
> File "/usr/lib/python2.7/argparse.py", line 1688, in parse_args
> args, argv = self.parse_known_args(args, namespace)
> File "/usr/lib/python2.7/argparse.py", line 1710, in parse_known_args
> default = self._get_value(action, default)
> File "/usr/lib/python2.7/argparse.py", line 2239, in _get_value
> raise ArgumentError(action, msg)
> argparse.ArgumentError: argument -t/--text: can't open '': [Errno 2]
> No such file or directory: ''
> make[3]: ***
[/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html]
> Error 1
> Locally it's compiled fine.
Yes I saw it, I don't know what's wrong there, Ivan do you have any idea?
Anyone has the same problem?
> Martin
Ciao
Luca
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150919/3b97ff31/attachment-0001.html>
