[GRASS-dev] How to get data from a location where the user does not own any mapset?
Radim Blazek
radim.blazek at gmail.com
Mon Sep 21 03:09:43 PDT 2015
Is it possible to access data through GRASS modules in a location
where the user does not own any mapset? Each GRASS module calls first
G_gisinit() which checks if current mapset returned by G_mapset() is
owned by current user. If it is not, it ends with fatal error. How to
get around this for locations where the user does not own any mapset?
Radim
