[GRASS-dev] table with the parser standard options
Moritz Lennert mlennert at club.worldonline.be
Mon Sep 21 04:11:58 PDT 2015
On 19/09/15 06:37, Luca Delucchi wrote:
> On 2 July 2015 at 09:49, Pietro <peter.zamb at gmail.com> wrote:
>> Dear Luca and Moritz,
> Dear All,
>> On Wed, Jul 1, 2015 at 11:58 AM, Moritz Lennert
>> <mlennert at club.worldonline.be> wrote:
>>> May I just suggest the following small modification
>> ok, added.
>>>> I believe we should add the generated table somewhere in the manual docs.
>>>> Should I add this python script to grass_addons/tools?
>>> Wouldn't it be better in tools/ directly in the source code ?
>> ok, committed in r65534.
>> Some examples:
>> $ python2 tools/parser_standard_options.py -t
>> lib/gis/parser_standard_options.c -f csv -o
>> parser_standard_options.csv
>> $ tail parser_standard_options.csv
>> G_OPT_STR3DS_INPUT;;Name of the input space time raster3d
>> dataset;;old,str3ds,str3ds;input;name;;;;YES;TYPE_STRING
>> G_OPT_STR3DS_INPUTS;;Name of the input space time raster3d
>> datasets;;old,str3ds,str3ds;inputs;name;;YES;;YES;TYPE_STRING
>> G_OPT_STR3DS_OUTPUT;;Name of the output space time raster3d
>> dataset;;new,str3ds,str3ds;output;name;;;;YES;TYPE_STRING
>> G_OPT_STDS_TYPE;strds;Type of the input space time
>> dataset;;;type;name;;;strds,stvds,str3ds;NO;TYPE_STRING
>> G_OPT_MAP_INPUT;;Name of the input map;;old,map,map;map;name;;;;YES;TYPE_STRING
>> G_OPT_MAP_INPUTS;;Name of the input
>> maps;;old,map,map;maps;name;;YES;;YES;TYPE_STRING
>> G_OPT_MAP_TYPE;raster;Type of the input
>> map;;;type;name;;;raster,vector,raster_3d;NO;TYPE_STRING
>> G_OPT_T_TYPE;absolute;The temporal type of the space time
>> dataset;;;temporaltype;name;;;absolute,relative;NO;TYPE_STRING
>> G_OPT_T_WHERE;;Example: start_time > '2001-01-01
>> 12:30:00';;;where;sql_query;WHERE conditions of SQL statement without
>> 'where' keyword used in the temporal GIS framework;;;NO;TYPE_STRING
>> G_OPT_T_SAMPLE;start;The method to be used for sampling the input
>> dataset;;;sampling;name;;YES;start,during,overlap,contain,equal,follows,precedes;NO;TYPE_STRING
>> lib/gis/parser_standard_options.c -f html -o
>> parser_standard_options.html
>> $ head parser_standard_options.html
>> <table border=1>
>>    <tr>
>>      <td>option</td>
>>      <td>answer</td>
>>      <td>description</td>
>>      <td>descriptions</td>
>>      <td>gisprompt</td>
>>      <td>key</td>
>>      <td>key_desc</td>
>>      <td>label</td>
>> parser_standard_options.csv -s Flg
>> description;key
>> G_FLG_V_TABLE;Do not create attribute table;'t'
>> G_FLG_V_TOPO;Do not build topology;'b'
> In r66263 I improved the tools of Pietro (specially I added a new
> GRASS output), moved it in man directory and added it to Makefile.
> It now return a batter table, you should see it at this link [0] after
> next manual compilation. Until now this page is not linked in any
> other manual's page, let me know where do you think should be
> better...
Great job, thanks !
It should certainly be linked to from the g.parser man page (in
replacement of the link to the programmer's manual).
Maybe there could also be a direct link in the "Miscellaneous &
Variables" section ?
Moritz
