[GRASS-dev] table with the parser standard options
Markus Neteler neteler at osgeo.org
Wed Sep 23 01:16:16 PDT 2015
On Wed, Sep 23, 2015 at 9:57 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> absolute path didn't work, I also tried to protect the values of the
> options but it didn't work too.
> The error seems the the option -t/--text is empty, could be a problem
> of argparse version?
Suggestion: add an "echo ..." there to print the actual line into the
log in order to better understand the issue?
Markus
