[GRASS-dev] [GRASS-SVN] r61363 - grass/branches/releasebranch_7_0/raster/r.in.gdal
Vaclav Petras
wenzeslaus at gmail.com
Thu Sep 24 08:51:28 PDT 2015
Hi Markus,
On Wed, Jul 23, 2014 at 5:43 AM, <svn_grass at osgeo.org> wrote:
> Author: neteler
> Date: 2014-07-23 02:43:05 -0700 (Wed, 23 Jul 2014)
> New Revision: 61363
> Modified:
> grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
> Log:
> r.in.gdal: GDALGetCacheMax() is limited to 2GiB, define valid range for
> memory parameter
> Modified: grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
> --- grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2014-07-23
> 09:33:12 UTC (rev 61362)
> +++ grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2014-07-23
> 09:43:05 UTC (rev 61363)
> @@ -101,6 +101,7 @@
> parm.memory->key = "memory";
> parm.memory->type = TYPE_INTEGER;
> parm.memory->required = NO;
> + parm.memory->options = "0-2047";
> parm.memory->description = _("Cache size (MiB)");
Any idea why 0-2047? r61362 message doesn't explain and in fact is related
to r61364. Shouldn't options be changed to something like 1-, 0- or
nothing? No reason to have upper limit, or is there some?
Thanks,
Vaclav
> parm.target = G_define_option();
> @@ -206,6 +207,7 @@
> GDALAllRegister();
> /* default GDAL memory cache size appears to be only 40 MiB, slowing
> down r.in.gdal */
> if (parm.memory->answer && *parm.memory->answer) {
> + /* TODO: GDALGetCacheMax() overflows at 2GiB, implement use of
> GDALSetCacheMax64() */
> GDALSetCacheMax(atol(parm.memory->answer) * 1024 * 1024);
> G_verbose_message(_("Using user memory cache size: %.1f MiB"),
> GDALGetCacheMax()/1024.0/1024.0);
> } else
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150924/aa24cef4/attachment.html>
