[GRASS-dev] Vect_open_old versus Vect_open_old2 and layer/field constraint
Vaclav Petras wenzeslaus at gmail.com
Mon Sep 28 09:02:14 PDT 2015
On Mon, Sep 28, 2015 at 11:22 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi,
> 2015-09-28 16:56 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> > what is the meaning for native vector maps? Does this limit the layer
as in
> > case of Vect_set_constraint_field() or do I actually have to call
> > Vect_set_constraint_field() to read features only in one layer?
> AFAIK currently it has no meaning to native maps, `layer` argument is
> used only by OGR direct access [1].
OK, thanks.
I have an additional question:
When getting field number to be used in Vect_set_constraint_field() and
with categories, should I use Vect_get_field_number()? The doc says "Get
field number of given field" but not when it should be used. I have seen it
in other modules but I'm not sure if this is correct, esp. for direct OGR
access.
> Ma
> [1]
https://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/open.c#L206
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150928/d4502d74/attachment.html>
