[GRASS-dev] [GRASS GIS] #2747: wxgui digitizer: display/update category values button does not work
trac at osgeo.org
Tue Sep 29 01:17:52 PDT 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 7.0.2
Component: wxGUI | Version: svn-trunk
Resolution: worksforme | Keywords: vector digitizer categories
CPU: Unspecified | Platform: Linux
Changes (by mlennert):
* status: new => closed
* resolution: => worksforme
Comment:
Replying to [comment:2 annakrat]:
> I can't reproduce it, everything works normally. Tested also with
wxpython 3, still no problem. Is your map 3D? That would explain it, but
it's still a bug.
I have no idea what happened. I tried several times yesterday, and
couldn't get it to work. Now it works perfectly. At total loss here to
explain...
For info: the map (census_wake2000) is not 3D.
Sorry for the noise. Closing the bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2747#comment:3>
