[GRASS-dev] Write array to (point) attribute table
Pietro
peter.zamb at gmail.com
Wed Sep 30 02:53:10 PDT 2015
On Wed, Sep 30, 2015 at 9:51 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> On Wed, Sep 30, 2015 at 2:02 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Tue, Sep 29, 2015 at 6:09 PM, Paulo van Breugel
>>> This must be a very basic question, but I can't find an easy/direct way
>>> to do this. In python, if I have an array with values with a length equal to
>>> the number of rows in an attribute table of a (point) vector layer, how can
>>> I write those values to a new column in that attribute table. I can of
>>> course first create the column, but than how to update that column with the
>>> values in the array?
>> it should be pretty easy to do with pygrass, unfortunately there is no
>> example on assigning attributes in the official documentation [1], but it
>> should be pretty easy, something like that (not tested):
>> with VectorTopo('myvector', mode='w') as vectormap:
>> for feature in vectormap:
>> feature.attrs['mycolumn'] = value
> Thanks, but that seems to write the vector back without attribute table
You have to save the changes in the database out from your cycle, with:
vectormap.table.conn.commit()
Pietro
