[GRASS-dev] Write array to (point) attribute table
Paulo van Breugel p.vanbreugel at gmail.com
Wed Sep 30 15:05:28 PDT 2015
On 30-09-15 17:52, Paulo van Breugel wrote:
> On 30-09-15 17:47, Anna Petrášová wrote:
>> On Wed, Sep 30, 2015 at 11:20 AM, Paulo van Breugel
>> <p.vanbreugel at gmail.com> wrote:
>>     On 30-09-15 16:18, Anna Petrášová wrote:
>>>     On Wed, Sep 30, 2015 at 9:27 AM, Paulo van Breugel
>>>     <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>>>         On Wed, Sep 30, 2015 at 11:53 AM, Pietro
>>>         <peter.zamb at gmail.com> wrote:
>>>             On Wed, Sep 30, 2015 at 9:51 AM, Paulo van Breugel
>>>             > On Wed, Sep 30, 2015 at 2:02 AM, Anna Petrášová
>>>             <kratochanna at gmail.com>
>>>             > wrote:
>>>             >> On Tue, Sep 29, 2015 at 6:09 PM, Paulo van Breugel
>>>             >>> This must be a very basic question, but I can't find
>>>             an easy/direct way
>>>             >>> to do this. In python, if I have an array with
>>>             values with a length equal to
>>>             >>> the number of rows in an attribute table of a
>>>             (point) vector layer, how can
>>>             >>> I write those values to a new column in that
>>>             attribute table. I can of
>>>             >>> course first create the column, but than how to
>>>             update that column with the
>>>             >>> values in the array?
>>>             >> it should be pretty easy to do with pygrass,
>>>             unfortunately there is no
>>>             >> example on assigning attributes in the official
>>>             documentation [1], but it
>>>             >> should be pretty easy, something like that (not tested):
>>>             >> with VectorTopo('myvector', mode='w') as vectormap:
>>>             >>     for feature in vectormap:
>>>             >>  feature.attrs['mycolumn'] = value
>>>             > Thanks, but that seems to write the vector back
>>>             without attribute table
>>>             You have to save the changes in the database out from
>>>             your cycle, with:
>>>             vectormap.table.conn.commit()
>>>         Thanks Pietro. I am, however, not sure I understand (I tried
>>>         to use it, but thanks to my limited experience in Python /
>>>         pygrass not much luck). Just to be more specific, I am
>>>         trying to create a script that divides points in training
>>>         and test groups, similar to v.kcv, but with points clustered
>>>         in space. E.g.,
>>>         # Create vector
>>>         grass.run_command("v.random", output="testB", npoints=10,
>>>         overwrite=True)
>>>         grass.run_command("v.db.addtable", map="testB", columns="X
>>>         DOUBLE PRECISION,Y DOUBLE PRECISION,GR INTEGER")
>>>         grass.run_command("v.to.db", map="test", option="coor",
>>>         columns="X,Y")
>>>         # Create groups
>>>         vectmap = 'test'
>>>         cvals = array(grass.vector_db_select(vectmap, layer =
>>>         int(1), columns = 'X,Y')['values'].values()).astype(np.float)
>>>         centroids,_ = kmeans(cvals,2)
>>>         idx,_ = vq(cvals,centroids)
>>>         # write results to tabel
>>>         Now I would like to write idx to the column 'GR' in the
>>>         attribute table of 'test'.
>>>         p.s. I am first creating the XY columns now, but is there a
>>>         function to get the coordinates (cvals) in pygrass directly?
>>>     I don't fully understand the example,
>>     Thanks for the quick response. I basically have a list with
>>     values (idx in the example above) which I like to add as a column
>>     to the attribute table of an existing vector (point layer). The
>>     length of idx is equal to the number of rows in the attribute
>>     table. The solution of Anna seems like an elegant solution (and
>>     easier and more flexible than other solutions I tried using e.g.,
>>     sqlite3). However, as I wrote, I end up with a vector without
>>     attribute table. You wrote that I "have to save the changes in
>>     the database out from your cycle, with:
>>     vectormap.table.conn.commit()". I am, however, not sure what you
>>     mean with 'out from your cycle' or how to implement that.
>> probably after the for cycle ends you would call this
>> 'vectormap.table.conn.commit()', if it doesn't works, try to put it
>> in the cycle (I am not sure what is supposed to work).
> I did try both, with no luck so-far. I'll give it another try though,
> perhaps I did something else wrong.
Tried out again, but after running the code below, I end up with an
empty vector layer (no points and no attribute table). Same if I put the
vectormap.table.conn.commit() in the for cycle.
import grass.script as grass
from grass.pygrass.vector import VectorTopo
grass.run_command("v.random", output="testB", npoints=10, overwrite=True)
grass.run_command("v.db.addtable", map="testB", columns="GR INTEGER")
with VectorTopo('testB', mode='w') as vectormap:
         feature.attrs['GR'] = 9
>>>     but yes, you can get coordinates:
>>>     print feature.x
>>>           print feature.y
>>     Great, thanks. I did not find this in the manual. If it is not
>>     there, perhaps it would be something worth including? I would not
>>     mind providing a text, but I am not sure what would be the best
>>     way to do that.
>> Technically, it's in the manual:
>> https://grass.osgeo.org/grass70/manuals/libpython/pygrass_vector.html#geometry-classes
>> but we are lacking more examples of often used constructions. Some
>> other examples are available in the recent workshop we did:
>> https://github.com/wenzeslaus/python-grass-addon/blob/master/02_pygrass_library.ipynb
> Thanks, I will have a look at it.
>>>             Pietro
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151001/541ec033/attachment-0001.html>
