[GRASS-dev] v.decimate: point cloud decimation of native vector maps
Vaclav Petras
wenzeslaus at gmail.com
Wed Sep 30 20:33:52 PDT 2015
Hi all,
I have added v.decimate to trunk in r66387 [1]. The current version can do
count-based decimation in the same way as the current v.in.lidar module
[2]. Additionally, a grid-based decimation is supported. The grid is 2D and
the points are preserved based on z, category or count (within one cell).
The grid-based decimation requires to store whole output (but not input) in
the memory, so it is not practical for large datasets. This will hopefully
change in the future. One way would be to employ same mechanism as in
r.in.lidar where we use small grid but we iterate multiple times over the
input dataset. Another ways are allocation of the cells on demand (instead
of whole grid based on region, perhaps necessary for 3D), keeping less
information per point (e.g. only z sum and count), or store something to
disk.
The module, especially at this stage, should be perhaps in addons rather
than trunk. However, the module already has some code overlap with
v.in.lidar and there is potential code overlap with other modules as well,
e.g. r.in.lidar. So, the idea is that some code will be moved to lib/lidar
and used by these modules. This v.decimate module is than a comfortable way
how to test the library functions.
The module currently lacks tests and code documentation, but I've already
prepared some user documentation [3].
Please comment and feel free to criticize the code quality etc. since I'm
planning to put it into the library eventually.
Vaclav
[1] https://trac.osgeo.org/grass/changeset/66387
[2] https://lists.osgeo.org/pipermail/grass-dev/2015-September/076275.html
[3] https://grass.osgeo.org/grass71/manuals/v.decimate.html
PDAL-related: The PDAL's counterpart to v.decimate is a the GridMinimum PCL
Block filter [4, 5, 6] which according to the documentation preserves point
with the minimum z value in each cell (as if r.in.lidar would have vector
output, but preserved xy position). The other, perhaps more similar, filter
in PDAL is voxelgrid [7] (based on PCL's VoxelGrid [8, 9]) which can do a
3D grid or 2D grid (if z resolution is large enough value). The result is
centroid of points within each grid cell/voxel (while v.decimate now
preserves xyz and layers/cats of the input).
[4] http://www.pdal.io/stages/filters.pclblock.html
[5] http://www.pdal.io/tutorial/pcl_spec.html#gridminimum
[6] http://docs.pointclouds.org/trunk/classpcl_1_1_grid_minimum.html
[7] http://www.pdal.io/stages/filters.voxelgrid.html
[8] http://www.pdal.io/tutorial/pcl_spec.html#voxelgrid
[9]
http://docs.pointclouds.org/trunk/classpcl_1_1_voxel_grid_3_01pcl_1_1_p_c_l_point_cloud2_01_4.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150930/5e813fdc/attachment.html>
