[GRASS-dev] [GRASS GIS] #2480: v.class.ml: ImportError: No module named training_extraction
GRASS GIS trac at osgeo.org
Fri Apr 1 08:58:56 PDT 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.0
 Component:  Addons       |    Version:  svn-releasebranch70
Resolution:               |   Keywords:  v.class.ml g.extension
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by martinl):
 Replying to [comment:16 lrntct]:
 > I did remove `~.grass7/addons` and the installation of v.class.ml
 worked. But it might worth investigating because a similar issue is still
 happening with other modules (cf. #2968).
 it will similar issue. Are you able to install now `r.agent`?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2480#comment:17>
