[GRASS-dev] [GRASS GIS] #2903: v.edit break bug with multiple coordinates
trac at osgeo.org
Thu Apr 7 03:22:06 PDT 2016
Reporter: robert17 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: 7.0.3
Resolution: | Keywords:
CPU: OSX/PPC | Platform: All
Comment (by jimmy):
Hello,
I think i have the same bug. Using grass 7.0.3 on MacOS, i created a
simple vector layer containing a simple line.
The projection system is EPSG:2154.
[http://i.imgur.com/xpIXaKf.png]
I then tried to break it using this v.edit command:
v.edit --overwrite --verbose map=testeditbreak at Jimmy tool=break
threshold=0.1,0,0 ids=1
coords=3722.5895,-4456546.5289,3443.3747,-4456366.5145
Result in the command line ([http://i.imgur.com/wQupaCQ.png])
Then [http://i.imgur.com/FoAACzn.png] show the attribute table with 4
lines all of the same lenght.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2903#comment:2>
