[GRASS-dev] [GRASS-user] Cannot launch g.copy from GRASS shell
Anna Petrášová
kratochanna at gmail.com
Sun Apr 10 12:14:10 PDT 2016
On Sun, Apr 10, 2016 at 3:03 PM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Try g.copy --ui
> It is obviously confusing that the --ui flag is needed for some modules to start the GUI...
I see. It's because there is no required parameter. It should be
solved using G_option_required(), but the options are in an array, so
I don't know how to use it in this case.
Anna
> Cheers
> Stefan
> -----Original Message-----
> From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of roy roy
> Sent: 10. april 2016 20:52
> To: GRASS user list <grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] Cannot launch g.copy from GRASS shell
> OK thanks Anna,
> what i'm going to describe happens in windows 64 bit osgeo4w GRASS and on ubuntu 64bit GRASS from "ubuntugis-unstable" ppa
> - open up GRASS GIS
> - on the shell / console (not in the GRASS GUI) write g.copy and hit ENTER
> - nothing happens
> if you do the same with another module (e.g. g.remove) the module gui regularly opens up
> Il 10/04/2016 20:22, Anna Petrášová ha scritto:
>> On Sun, Apr 10, 2016 at 10:31 AM, roy roy <royroge at outlook.com> wrote:
>>> While i can launch g.copy from the GRASS gui i cannot launch the
>>> exact same module from the shell, is there some sort of bug?
>> It should work, please be more specific - any error? which platform?
>> GRASS version?
>> Best,
>> Anna
>>> thanks, roy.
>>> grass-user mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
