[GRASS-dev] creating temporary mapsets in a parallelized python	script
    Vaclav Petras
    wenzeslaus at gmail.com
    Mon Apr 11 15:13:46 PDT 2016
On Mon, Apr 11, 2016 at 5:19 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> > I see, then it's easier to fix the script and use grass.use_temp_region
> From the manual:
> script.core.use_temp_region()[source]¶
> Copies the current region to a temporary region with “g.region save=”, then
> sets WIND_OVERRIDE to refer to that region. Installs an atexit handler to
> delete the temporary region upon termination.
> Does this function mean that: while concurrent r.basin runs on different
> CPUs in the same mapset, there is no interefering by region settings change
> interefering?
Setting WIND_OVERRIDE (environmental variable) will happen for the current
process, so it won't affect other processes only subprocess which is
desired. (In your case, this won't work if you would use this function
outside of r.basin.) So yes, parallel processes (including g.region) won't
see WIND_OVERRIDE, so they will see and use the original computational
region.
The documentation describes just what happens in the background but not the
usage. Feel free to update that with your understanding.
Generally, use_temp_region should be used by any module which calls
g.region.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160411/54483555/attachment.html>
