[GRASS-dev] [GRASS GIS] #2928: query tool does not work in wx display
trac at osgeo.org
Tue Apr 12 07:26:53 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: query tool
CPU: x86-64 | Platform: Linux
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:3 veroandreo]:
> Thanks, Anna! Works fine now both using d.mon and the main map display
in the GUI. However, in both cases, the first time I click over the
displayed map, I still get this message in the terminal:
> (main.py:9791): Gtk-CRITICAL **: gtk_widget_set_size_request: assertion
'height >= -1' failed
Thanks. The gtk error is unrelated and I think harmless.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2928#comment:4>
