[GRASS-dev] [GRASS-user] data catalog question
Anna Petrášová kratochanna at gmail.com
Tue Apr 12 09:21:31 PDT 2016
On Tue, Apr 12, 2016 at 10:52 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hi Anna
> I just updated GRASS trunk version (GRASS GIS 7.1.svn r68252) to test the
> data catalogue. However, when opening the data tab in the main GUI, after
> some waiting, the GUI crashes with:
> GRASS_INFO_ERROR(30614,1): Mapset <backup> does not exist
this error comes from g.list mapset=backup ...
and 'backup' comes from running 'g.mapsets -l' for each location.
Could you run it in the problematic location? Do you get then
'backup'? Also you can try to switch on debug mode.
I don't know what the rest of the errors mean. If you find the
problem, I can try to reproduce it.
Anna
> GRASS_INFO_END(30614,1)
> python: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
> There was indeed a reference to a non-existing backup mapset in one of the
> SEARCH_PATH files, but also after removing that reference, I am getting the
> same crash with message (below), which makes me wonder where else to look
> for a reference to an non-existing mapset.
> GRASS_INFO_ERROR(32753,1): Mapset <backup> does not exist
> GRASS_INFO_END(32753,1)
> I tried it again, and got a slightly different message:
> GRASS_INFO_ERROR(31864,1): Mapset <backup> does not exist
> GRASS_INFO_END(31864,1)
> Xlib: request 54 length 8 would exceed buffer size.
> and yet another time, with the message below, which does not seem terribly
> helpful, but I am copying anyway.
> GRASS_INFO_END(32455,1)
> The program 'python' received an X Window System error.
> This probably reflects a bug in the program.
> The error was 'BadLength (poly request too large or internal Xlib length
> erro'.
>   (Details: serial 15786 error_code 16 request_code 139 minor_code 4)
>   (Note to programmers: normally, X errors are reported asynchronously;
>    that is, you will receive the error a while after causing it.
>    To debug your program, run it with the --sync command line
>    option to change this behavior. You can then get a meaningful
>    backtrace from your debugger if you break on the gdk_x_error() function.)
> erro'.
>   (Details: serial 15795 error_code 16 request_code 130 minor_code 0)
> On 10-04-16 05:00, Anna Petrášová wrote:
>> Hi,
>> I was wondering what is the opinion about the new data catalog (in
>> trunk), specifically, whether users should be able to modify (copy,
>> rename, delete) maps from other mapsets and locations than the current
>> ones. I find it very useful to edit any mapsets, but it goes against
>> the traditional GRASS approach. I have this (edit anything behavior)
>> implemented locally, but wanted to know before committing if people
>> agree with that.
>> Thanks,
>> Anna
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
