[GRASS-dev] [GRASS-user] data catalog question
Anna Petrášová
kratochanna at gmail.com
Tue Apr 12 20:24:54 PDT 2016
On Tue, Apr 12, 2016 at 2:29 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Tue, Apr 12, 2016 at 2:21 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
>> On 12-04-16 18:21, Anna Petrášová wrote:
>>> On Tue, Apr 12, 2016 at 10:52 AM, Paulo van Breugel
>>>> Hi Anna
>>>> I just updated GRASS trunk version (GRASS GIS 7.1.svn r68252) to test the
>>>> data catalogue. However, when opening the data tab in the main GUI, after
>>>> some waiting, the GUI crashes with:
>>>> GRASS_INFO_ERROR(30614,1): Mapset <backup> does not exist
>>> this error comes from g.list mapset=backup ...
>>> and 'backup' comes from running 'g.mapsets -l' for each location.
>>> Could you run it in the problematic location? Do you get then
>>> 'backup'? Also you can try to switch on debug mode.
>> Found the problem. In one of the locations I had a copy of a mapset folder
>> 'Dispersal' which I named 'Dispersal backup', so it is the space in the name
>> of the second one that caused the problem.
> I'll try to reproduce it and see if it can be handle this situation better
>>> I don't know what the rest of the errors mean. If you find the
>>> problem, I can try to reproduce it.
>>> Anna
Weird, I created a mapset with space in the name and everything works...
>>>> On 10-04-16 05:00, Anna Petrášová wrote:
>>>>> Hi,
>>>>> I was wondering what is the opinion about the new data catalog (in
>>>>> trunk), specifically, whether users should be able to modify (copy,
>>>>> rename, delete) maps from other mapsets and locations than the current
>>>>> ones.
>> So now I could try out the new functionality. I can display or copy maps
>> from other mapsets, but only if in the same location. If I am in another
>> location, there is still the option to display or copy in the context menu
>> (right click), but when selecting copy, there is the error message that
>> "failed to copy: action is allowed only within the same mapset". When
>> selecting 'display', the message is "failed to display: not in current
>> mapset or invalid layer".
> sorry, I still haven't committed it yet, I haven't added the option to
> change it from settings yet, I'll try to add it later today...
I committed the changes, please test...
Anna
>>>>> I find it very useful to edit any mapsets, but it goes against
>>>>> the traditional GRASS approach. I have this (edit anything behavior)
>>>>> implemented locally, but wanted to know before committing if people
>>>>> agree with that.
>>>>> Thanks,
>>>>> Anna
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
