[GRASS-dev] [GRASS GIS] #2986: r.mapcalc with same variable on LHS and RHS
trac at osgeo.org
Thu Apr 14 01:02:13 PDT 2016
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.4
Component: Docs | Version: 7.0.3
Resolution: | Keywords: r.mapcalc
CPU: Unspecified | Platform: Unspecified
Comment (by marisn):
Such notice is already present in documentation (introduced in r66548 on
20 Oct 2015). See: https://grass.osgeo.org/grass71/manuals/r.mapcalc.html
... expression is any legal arithmetic expression involving existing
raster map layers (except result itself) ...
See also:
#2770;
https://lists.osgeo.org/pipermail/grass-dev/2011-July/054983.html
Either this bug should be closed or it should be turned into a wish - to
not allow same LHS variable to appear on RHS. As I'm not so much into
mapcalc language details, I can not see it as a problem, but Glynn will
shed more light on such option.
Mankoff, if you consider current documentation to be inadequate, provide a
patch with better wording.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2986#comment:1>
