[GRASS-dev] creating temporary mapsets in a parallelized python script
Pietro
peter.zamb at gmail.com
Thu Apr 14 05:39:09 PDT 2016
> The main issue with use_temp_region() is that the clean-up function
> uses the current value of the environment variable to determine which
> region to delete.
> This could be fixed by passing a lambda to atexit.register(), e.g.
> def use_temp_region():
> name = "tmp.%s.%d" % (os.path.basename(sys.argv[0]), os.getpid())
> run_command("g.region", save=name, overwrite=True)
> os.environ['WIND_OVERRIDE'] = name
> atexit.register(lambda: run_command("g.remove", flags='f', quiet=True, type='region', name=name))
Perhaps we could decorate the function with contextmanager:
from contextlib import contextmanager
@contextmanager
def use_temp_region(**reg):
original = region()
try:
reg = parse_command("g.region", save=name, overwrite=True, **reg)
yield reg
finally:
# clean created variable and region
print('WIND_OVERRIDE' in os.environ)
os.environ.pop('WIND_OVERRIDE')
# restore previous region
for key in 'projection,zone,cells'.split(','):
original.pop(key)
run_command("g.region", **original)
and then use the function with:
run_command("g.region", flags='p')
print('=' * 30)
with use_temp_region(res=100) as tmp_region:
print('=' * 30)
print('=' * 30)
All the best
Pietro
