[GRASS-dev] [GRASS GIS] #2988: Install additional hicolor icon sizes
trac at osgeo.org
Fri Apr 15 10:53:14 PDT 2016
Reporter: sebastic | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.4
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords:
CPU: All | Platform: Linux
Comment (by sebastic):
The .ico is not installed (because "using different icons can be confusing
for the user" according to the comment in the Makefile), and the 48x48 and
64x64 PNG icons also use a transparent background.
A transparent background fits better with different themes especially dark
ones where the white icon doesn't fit well. This is in line with the
[https://specifications.freedesktop.org/icon-theme-spec/icon-theme-spec-
latest.html#install_icons Icon Theme Specification] which recommends:
> It is recommended that the icons installed in the hicolor theme look
neutral, since it is a fallback theme that will be used in combination
with some very different looking themes. But if you don't have any neutral
icon, please install whatever icon you have in the hicolor theme so that
all applications get at least some icon in all themes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2988#comment:2>
