[GRASS-dev] [GRASS GIS] #2995: wxGUI start fails with charmap codec can't decode byte from g.version
GRASS GIS trac at osgeo.org
Wed Apr 20 14:16:55 PDT 2016
 Reporter:  wenzeslaus                           |      Owner:  grass-dev@…
     Type:  defect                               |     Status:  new
 Priority:  blocker                              |  Milestone:  7.0.4
Component:  wxGUI                                |    Version:  svn-
 Keywords:  g.version, version, packaging,       |  releasebranch70
  wxGUI, compilation, locales, encoding          |        CPU:  x86-32
 Platform:  MSWindows 8                          |
 The main GUI (g.gui) in 7.0.4RC1 32bit fails to start because of non-ascii
 characters in `g.version -rge`, namely in `libgis_date` entry which is
 `"2015-12-24 16:07:44 +0100 (Ä?t, 24 12 2015) "` (I assume "Út", i.e. date
 with locales instead of some ASCII). The tested computer has some US
 locales.
 Perhaps wxGUI should deal with that by some different handling (I don't
 know what `charmap` is and how computes encoding influences that) or by
 ignoring all errors and not showing the version (but maybe the version is
 needed also elsewhere).
 7.1 (trunk) works.
   File "C:\Program Files (x86)\GRASS GIS 7.0.4RC1\gui\wxpython\wxgui.py",
 line 1
 48, in <module>
     sys.exit(main())
 line 1
 35, in main
     app = GMApp(workspaceFile)
 line 5
 0, in __init__
     wx.App.__init__(self, False)
   File "C:\Program Files (x86)\GRASS GIS 7.0.4RC1\Python27\lib\site-
 packages\wx-
 2.8-msw-unicode\wx\_core.py", line 7981, in __init__
     self._BootstrapApp()
 packages\wx-
 2.8-msw-unicode\wx\_core.py", line 7555, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
 line 8
 4, in OnInit
     workspace=self.workspaceFile)
 7.0.4RC1\gui\wxpython\lmgr\frame.py", l
 ine 93, in __init__
     grassVersion = grass.version()['version']
 7.0.4RC1\etc\python\grass\script\core.p
 y", line 1502, in version
     data = parse_command('g.version', flags='rge', errors='ignore')
 y", line 488, in parse_command
     return parse(res, **parse_args)
 7.0.4RC1\etc\python\grass\script\utils.
 py", line 218, in parse_key_val
     v = decode(kv[1].strip())
 py", line 160, in decode
     return string.decode(enc)
 7.0.4RC1\Python27\lib\encodings\cp1252.
 py", line 15, in decode
     return codecs.charmap_decode(input,errors,decoding_table)
 UnicodeDecodeError: 'charmap' codec can't decode byte 0x8d in position 29:
  character maps to <undefined>
 > g.version -rge
 version=7.0.4RC1
 date=2016
 revision=68279
 build_date=2016-04-19
 build_platform=i386-w64-mingw32
 libgis_revision=67364
 libgis_date="2015-12-24 16:07:44 +0100 (Ä?t, 24 12 2015) "
 proj4=4.9.2
 gdal=2.0.2
 geos=3.5.0
 sqlite=3.7.17
Ticket URL: <https://trac.osgeo.org/grass/ticket/2995>
