[GRASS-dev] [GRASS GIS] #2994: wxGUI start fails with module object has no attribute GRIORA_NearestNeighbour
trac at osgeo.org
Thu Apr 21 07:02:16 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: closed
Priority: blocker | Milestone: 7.0.4
Component: wxGUI | Version: svn-releasebranch70
Resolution: invalid | Keywords: gdal, Python, WMS, rendering,
| packaging, wxGUI
CPU: x86-64 | Platform: Unspecified
Changes (by wenzeslaus):
* status: new => closed
* resolution: => invalid
Comment:
I can't reproduce it anymore with newly downloaded build from today, Apr
21 (which is still r68280). Closing as invalid. We can reopen if needed.
The following 7.0.4svn 32bit and 64bit worked:
System Info
GRASS version: 7.0.4svn
GRASS SVN Revision: 68280
Build Date: 2016-04-21
Build Platform: x86_64-w64-mingw32
GDAL/OGR: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200
> g.version -re
GRASS 7.0.4svn (2016)
libgis Revision: 67364
libgis Date: 2015-12-24 16:07:44 +0100 (Thu, 24 Dec 2015)
PROJ.4: 4.9.2
GDAL/OGR: 2.0.2
GEOS: 3.5.0
SQLite: 3.7.17
System Info
Build Platform: i386-w64-mingw32
GDAL/OGR: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
> g.version -re
PROJ.4: 4.9.2
GDAL/OGR: 2.0.2
GEOS: 3.5.0
SQLite: 3.7.17
Ticket URL: <https://trac.osgeo.org/grass/ticket/2994#comment:4>
