[GRASS-dev] [GRASS GIS] #2998: m.nviz.image fails with X Error BadValue integer parameter out of range for operation
GRASS GIS trac at osgeo.org
Fri Apr 22 14:46:39 PDT 2016
operation
 Reporter:  wenzeslaus                           |      Owner:  grass-dev@…
     Type:  defect                               |     Status:  new
 Priority:  normal                               |  Milestone:  7.1.0
Component:  LibOpenGL                            |    Version:  svn-trunk
 Keywords:  m.nviz.image, NVIZ, 3D, GLX,         |        CPU:  x86-64
  X_GLXCreateContext, g.gui.animation            |
 Platform:  Linux                                |
 G7:m.nviz.image fails to render the image. (3D view in wxGUI works well.)
 Generating vector points (fails for any data):
 v.random -z output=points n=100 zmin=0 zmax=20
 # or
 # r.surf.fractal fractal
 Running, m.nviz.image:
 m.nviz.image vpoint=points vpoint_size=5 vpoint_layer=1 \
   position=0.84,0.16 height=600 perspective=30 focus=172,136,0 \
   output=nviz_output format=ppm size=798,530
 The error:
 X Error of failed request:  BadValue (integer parameter out of range for
 operation)
   Major opcode of failed request:  154 (GLX)
   Minor opcode of failed request:  3 (X_GLXCreateContext)
   Value in failed request:  0x0
   Serial number of failed request:  24
   Current serial number in output stream:  29
 GRASS version:
 > g.version -re
 GRASS 7.1.svn (2016)
 libgis Revision: 67275
 libgis Date: 2015-12-20 07:50:48 -0500 (Sun, 20 Dec 2015)
 PROJ.4: 4.9.1
 GDAL/OGR: 1.11.2
 GEOS: 3.5.0
 SQLite: 3.8.11.1
 Computer and system info:
 $ lsb_release -a
 No LSB modules are available.
 Distributor ID: Ubuntu
 Description:    Ubuntu 15.10
 Release:        15.10
 Codename:       wily
 $ lspci -v  # selected lines only
 00:02.0 VGA compatible controller: Intel Corporation Sky Lake Integrated
 Graphics (rev 07) (prog-if 00 [VGA controller])
         Subsystem: CLEVO/KAPOK Computer Device 2425
         Flags: bus master, fast devsel, latency 0, IRQ 126
         Memory at de000000 (64-bit, non-prefetchable) [size=16M]
         Memory at c0000000 (64-bit, prefetchable) [size=256M]
         I/O ports at f000 [size=64]
         Expansion ROM at <unassigned> [disabled]
         Capabilities: <access denied>
         Kernel driver in use: i915
 $ sudo dmidecode -q | grep -iE "Manufacturer|Product Name" | sed
 's/[[:blank:]]\{2,\}//g' | sort | uniq
         Manufacturer: Intel(R) Corporation
         Manufacturer: Samsung
         Manufacturer: System76, Inc.
         Product Name: Lemur
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998>
