[GRASS-dev] [GRASS-user] 64bit GRASS for Mac
Michael Barton Michael.Barton at asu.edu
Mon Apr 25 09:46:23 PDT 2016
Stuart,
wxPython is bundled. I just checked with my copy. Is anyone else having this problem? Maybe there is a link error. I will check.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Apr 25, 2016, at 9:30 AM, Stuart Edwards <sedwards2 at cinci.rr.com<mailto:sedwards2 at cinci.rr.com>> wrote:
Michael
On start up I get the following error:
ImportError: dlopen(/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core_.so, 2): Library not loaded: /usr/local/lib/wxPython-3.0.2.0/lib/libwx_osx_cocoau-3.0.0.2.0.dylib
  Referenced from: /Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core_.so
  Reason: image not found
It seems to be looking for wxPython in /usr/local/lib. Previously wxPython was part  of the bundle - do I now need to install it independently?
thx
Stu
On Friday, I posted a full 64 bit version of GRASS 7.1 onto the GRASS for Mac web site (http://grassmac.wikidot.com<http://grassmac.wikidot.com/>) for testing. It uses wxPython 3.0.2.0 (but still uses system Python 2.7). No other change to any frameworks that are already posted on that site.  It seems to mostly work fine, but I noticed a couple of small quirks in preliminary testing. The dev team will need bug reports on things that don't work so that they can be fixed.
Be aware that it will overwrite any existing GRASS 7.1 you have unless you rename your existing 7.1 prior to installing.
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160425/5867ebfc/attachment-0001.html>
