[GRASS-dev] [GRASS GIS] #3001: r.in.xyz -s scan mode: one row/col lost?
GRASS GIS trac at osgeo.org
Mon Apr 25 16:05:53 PDT 2016
 Reporter:  neteler   |      Owner:  grass-dev@…
     Type:  defect    |     Status:  new
 Priority:  normal    |  Milestone:  7.0.4
Component:  Raster    |    Version:  svn-trunk
 Keywords:  r.in.xyz  |        CPU:  All
 Platform:  Linux     |
 While preparing an example how to import X,Y,Z ASCII DEMs which look like
 this:
 630007.5 228492.5 141.99614
 630022.5 228492.5 141.37904
 630037.5 228492.5 142.29822
 630052.5 228492.5 143.97987
 for the page
 https://grass.osgeo.org/grass70/manuals/r.in.xyz.html#import-of-x,y
 ,string-data
 I came across the issue that one row/col seems to be lost in the scan mode
 of r.in.xyz. If true this may have some relevance for Lidar processing,
 too.
 Test case:
 #### GRASS 7.0.4svn (nc_spm_08_grass7):~ >
 # export as X,Y,Z ASCII
 g.region raster=elevation -p
 projection: 99 (Lambert Conformal Conic)
 zone:       0
 datum:      nad83
 ellipsoid:  a=6378137 es=0.006694380022900787
 north:      228500
 south:      215000
 west:       630000
 east:       645000
 nsres:      10
 ewres:      10
 rows:       1350
 cols:       1500
 cells:      2025000
 # export (cell centers)
 r.stats -1g elevation > elevation.xyz
 head -n 4 elevation.xyz
 630005 228495 141.99614
 630015 228495 141.27849
 630025 228495 141.37904
 630035 228495 142.29822
 wc -l elevation.xyz
 2025000 elevation.xyz
 # ... looks ok.
 #### import
 # scan extent from xyz input
 r.in.xyz input=elevation.xyz separator=space -s output=dummy -g
 n=228495 s=215005 e=644995 w=630005 b=55.578793 t=156.32986
 # set region
 g.region n=228495 s=215005 e=644995 w=630005 -p
 zone:       0
 datum:      nad83
 north:      228495
 south:      215005
 west:       630005
 east:       644995
 nsres:      10
 ewres:      10
 rows:       1349
 cols:       1499
 cells:      2022151
 ## -->> one col and one row lost?!
 r.in.xyz input=elevation.xyz separator=space method=mean output=myelev
 r.in.xyz complete. 2022151 points found in region.
 ## -->> incomplete
Ticket URL: <https://trac.osgeo.org/grass/ticket/3001>
