[GRASS-dev] [GRASS GIS] #3005: v.to.rast allow to use label_column alone
trac at osgeo.org
Wed Apr 27 01:28:34 PDT 2016
Reporter: marisn | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Keywords: v.to.rast | CPU: Unspecified
Platform: Unspecified |
At the moment v.to.rast only supports label_column together with
attr_column. It makes perfect sense, still misses one use case - when
attr_column is absent and only labels are present. I.e. when attribute
table contains land use labels but not class codes.
Proposal is to generate codes on the fly if only label column is provided.
How it could work: select labelcolumn from db distinct; Enumerate output
rows; Use row number as a raster category.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3005>
