[GRASS-dev] [GRASS GIS] #3006: Large attribute table causes buffer overflow in v.db.select
trac at osgeo.org
Thu Apr 28 00:22:27 PDT 2016
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Resolution: fixed | Keywords: v.db.select
CPU: Unspecified | Platform: Linux
Changes (by marisn):
* status: new => closed
* resolution: => fixed
* component: wxGUI => Vector
Comment:
Sorry, Anna, I was partially wrong. After examining dbmgr.base
!VirtualAttributeList with lots of print's, I came down to line joining
all column names to pass them to v.db.select.
([https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/dbmgr/base.py#L210
Line 120 of dbmgr/base.py]) Thus it was causing an overflow in select
statement of v.db.select and I could not see it from CLI, as I was running
it without explicitly stating all columns. Once I saw exact command
executed by wxGUI, fixing it was easy.
I bumped up string buffer for storing query from 1024 to 4096 in r68321
(backported to 7.0 in r68322). Should be enough for most of cases as "640k
should be enough for everyone".
Ticket URL: <https://trac.osgeo.org/grass/ticket/3006#comment:4>
