[GRASS-dev] [GRASS-SVN] r68329 - grass/trunk/lib/gis
Markus Neteler
neteler at osgeo.org
Fri Apr 29 06:56:40 PDT 2016
On Fri, Apr 29, 2016 at 3:20 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, Apr 29, 2016 at 6:33 AM, <svn_grass at osgeo.org> wrote:
>> # v.db.select
>> v.db.select|nv:null_value
>> +v.db.select|fs:separator
>> v.db.select|vs:vertical_separator
> Shouldn't the "global block" in renamed_options take care of nv and fs?
ah, I overlooked that!
> https://trac.osgeo.org/grass/changeset/68329
Question: are modules automagically picked up for global block or do
they need to be listed?
If the former, shall I revert 68329?
Markus
