[GRASS-dev] grass 7.2 planning
Vaclav Petras
wenzeslaus at gmail.com
Sat Apr 30 05:59:27 PDT 2016
On Sat, Apr 30, 2016 at 8:09 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> 2016-04-29 15:09 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> > I have some things in lidar modules which would be good to do before the
> > branching, namely changing the layer options to flag(s) and removal of
> > vector output from r.in.lidar. Ideally, some code should go from
modules to
> > the library but that might not be feasible in the given time frame
(from my
> > side). The first week of May I can't promise any commits since I'm at
FOSS4G
> > NA [1]
> we can wait one week or so if you wish.
Thanks. This would give at least some chance to get things straight.
> > From things I remember, there is the prototype of Simple Python Editor
which
> > needs a review but you (Martin) already did some, so I guess that's
fine.
> Yes, I used the editor in lessons. Nice tool!
Thanks. It took me some time to discover that this is exactly what users
want.
> I had only one problem,
> sometimes run button was not working (I discovered why after lesson)
I focused on getting the basics working but the executing is just tricky.
Will try to look at it as well to see if some substantial changes are
needed.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160430/0c0bd4a5/attachment-0001.html>
