[GRASS-dev] grass 7.2 planning
Vaclav Petras
wenzeslaus at gmail.com
Sat Apr 30 10:26:15 PDT 2016
Hi Michael,
I'm currently looking at the lidar-related functionality, so here is some
info.
On Sat, Apr 30, 2016 at 12:28 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> Related to this, is there a plan to replace liblas with the new Python
> alternative (the name escapes me at the moment)? This would further
> simplify making robust LiDAR tools available in GRASS
On Sat, Apr 30, 2016 at 12:36 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> The LiDAR tools I was thinking of is PDAL.
> http://www.pdal.io
You can try compile GRASS with PDAL right now. Just note that PDAL is not a
drop-in replacement for libLAS and so far the PDAL functionality is
available only through special module v.in.pdal. See #2732 [1] for details.
> I guess it's C++.
Yes, it's C++ not C or Python and it currently does not have C API, so it
might be even harder to connect in general. The basic functionality newly
(since release 1.2) does not depend on Boost but the new C++ (I think
C++11) is needed. It is important to note that most of the fancy
functionality (like ground detection) is provided through another
dependency, PCL (http://pointclouds.org/), which is a large point cloud
processing library which depends on Boost (if I recall correctly).
But it's open source without some of the legal and compiling issues of
> LAStools.
With the current GRASS source code we are able to use only libLAS (
http://www.liblas.org/), not LAStools (https://rapidlasso.com/lastools/)
[2].
Best,
Vaclav
[1] https://trac.osgeo.org/grass/ticket/2732
[2] https://lists.osgeo.org/pipermail/grass-dev/2015-September/076318.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160430/83671186/attachment.html>
