[GRASS-dev] [GRASS GIS] #3108: db selection: integer overflow
trac at osgeo.org
Tue Aug 2 04:00:50 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Database | Version: svn-trunk
Resolution: | Keywords: v.db.univar db.select overflow
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
Not sure if this is related:
But also here GRASS tools give a buffer overflow whlie sqlite3 works:
This is my query example:
g.copy vector="geonames_NC,geonames_NC_cp"
v.db.addcolumn map=geonames_NC_cp columns="test integer"
cats=$(v.db.select -c geonames_NC_cp columns=cat where=cat< 25000)
echo "UPDATE geonames_NC_cp SET test = 1 WHERE cat in (${cats});" >
db_test.sql
Then db.execute results in a core dump:
db.execute input=db_test.sql
while
sqlite3 /grassdata/nc_spm_08_grass/sbl/sqlite/sqlite.db < db_test.sql
works without issues...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3108#comment:1>
