[GRASS-dev] m.printws - new module recommendation/announcement
Robert Kuszinger kuszinger at giscom.hu
Wed Aug 3 07:15:59 PDT 2016
Hi all,
I've created a new python script which generates:
   - quick printout (pdf) from workspace definitions
   - supports multiple display definitions in one workspace ( = multiple
   printouts in one run)
   - UTF-8 text could also be printed (ps.map supports only latin1, this
   was the initial reason to create alternative print method)
known major issues:
   - barscale and northarrow positioning should be revised in the
   respective d.* modules
   - ImageMagick dependency should be eliminated longer term
   - regexp processing of workspace files instead of formal XML processing
   - needs more calibration on txt/symbol resizing according to printout
   dpi change
This module is NOT for professional prints but for quick&dirty and
hopefully comfortable
printout making.
Tested under:
   - Linux: 7.0.4,7.2 latest, 7.3 weekly snapshot
   - Windows: 7.3 binary OSGeo4W
Source and doc are here:
https://github.com/kuszinger/giscomgrass7addons/tree/master/m.printws
best regards
Robert
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160803/e9c2d1c2/attachment-0001.html>
