[GRASS-dev] [GRASS GIS] #3112: wxgui scatterplot tool: C++ assertion "m_window" failed at ../src/gtk/dcclient.cpp(2043) in DoGetSize(): GetSize() doesn't work without window
trac at osgeo.org
Thu Aug 4 06:11:39 PDT 2016
without window
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.5
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: scatterplot
CPU: Unspecified | Platform: Unspecified
Comment (by annakrat):
Replying to [comment:8 mlennert]:
> Replying to [comment:7 annakrat]:
> > Fixed in r69075 (and backported in r69076 and r69077). wxPython file
wx.lib.plot.py (the fixed version, see
http://trac.wxwidgets.org/ticket/16767) is now distributed with GRASS and
modified to workaround this bug specific for wxGTK only:
> > http://trac.wxwidgets.org/ticket/17293
> I imagine that this should only be temporary: as soon as the bug is
fixed in a new wxpython distribution, we should not maintain that code in
our code base.
Yes, the problem is nobody knows if and when classic wxPython 3 is
released.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3112#comment:9>
