[GRASS-dev] [GRASS GIS] #3118: Some modules fail to compile
GRASS GIS trac at osgeo.org
Thu Aug 4 17:56:46 PDT 2016
  Reporter:  ewcgrass   |      Owner:  grass-dev@…
      Type:  defect     |     Status:  new
  Priority:  normal     |  Milestone:  7.2.0
 Component:  Compiling  |    Version:  svn-releasebranch72
Resolution:             |   Keywords:
       CPU:  x86-64     |   Platform:  Linux
Comment (by wenzeslaus):
 These all are modules with non-trivial dependencies (v.buffer - GEOS,
 r.in.lidar and v.in.lidar - libLAS, v.out.postgis - libpq). Please, check
 the configure command and the configure log (this will hopefully tell
 more).
 Everything seems to work after compilation (just make, no install) for me
 on Ubuntu with trunk and 72 branch.
 ./configure \
   --with-geos \
   --with-liblas \
   --with-postgres=yes --with-postgres-includes="/usr/include/postgresql" \
   GEOS support:               yes
   libLAS support:             yes
   PostgreSQL support:         yes
 $ ls dist.x86_64-pc-linux-
 gnu/*/{v.out.postgis,v.in.lidar,v.in.lidar,v.buffer}
 dist.x86_64-pc-linux-gnu/bin/v.buffer    dist.x86_64-pc-linux-
 gnu/bin/v.in.lidar
 dist.x86_64-pc-linux-gnu/bin/v.in.lidar  dist.x86_64-pc-linux-
 gnu/bin/v.out.postgis
Ticket URL: <https://trac.osgeo.org/grass/ticket/3118#comment:1>
