[GRASS-dev] [GRASS GIS] #3118: Some modules fail to compile
GRASS GIS trac at osgeo.org
Fri Aug 5 09:50:38 PDT 2016
  Reporter:  ewcgrass   |      Owner:  grass-dev@…
      Type:  defect     |     Status:  new
  Priority:  normal     |  Milestone:  7.2.0
 Component:  Compiling  |    Version:  svn-releasebranch72
Resolution:             |   Keywords:
       CPU:  x86-64     |   Platform:  Linux
Comment (by ewcgrass):
 Thanks for your prompt reply.
 FYI, this is on Fedora 21 (yes, no longer supported, but with latest
 updates installed).
 I compiled originally with default settings, and geos, liblas and postgres
 support are excluded by default (perhaps a change is required to include
 them by default?).
 By including support for geos and liblas (I didn't include support for
 postgres in case it removed default support for SQlite?, which I wish to
 maintain), and installing laszip-devel and libgeotiff-devel and making
 links to original files to create libboost_program_options.so and
 libboost_thread.so to remedy failed configurations, all finally configured
 fine. A file with copy of the command used and output obtained, and
 config.log, are attached.
 However, now compilation fails at v.buffer. Running "make" inside
 /vector/v.buffer directory yields this:
 --snip--
 [rick at localhost v.buffer]$ make
 test -d OBJ.x86_64-pc-linux-gnu || mkdir -p OBJ.x86_64-pc-linux-gnu
 gcc  -g -Wall   -I/home/rick/temp/newapps/apps/science/gis-
 mapping/grass/grass72/grass-7.2.svn_src_snapshot_2016_07_30/dist.x86_64
 -pc-linux-gnu/include -I/home/rick/temp/newapps/apps/science/gis-
 -pc-linux-gnu/include   -I/usr/include/gdal -I/usr/include -I/usr/include
 -DPACKAGE=\""grassmods"\"   -I/home/rick/temp/newapps/apps/science/gis-
 -pc-linux-gnu/include -DRELDIR=\"vector/v.buffer\" -o OBJ.x86_64-pc-linux-
 gnu/main.o -c main.c
 gnu/geos.o -c geos.c
 : && gcc -L/home/rick/temp/newapps/apps/science/gis-
 -pc-linux-gnu/lib -L/home/rick/temp/newapps/apps/science/gis-
 -pc-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-
 link,/home/rick/temp/newapps/apps/science/gis-
 -pc-linux-gnu/lib -o /home/rick/temp/newapps/apps/science/gis-
 -pc-linux-gnu/bin/v.buffer OBJ.x86_64-pc-linux-gnu/main.o OBJ.x86_64-pc-
 linux-gnu/geos.o    -lgrass_vector.7.2.svn -lgrass_dbmiclient.7.2.svn
 -lgrass_dbmibase.7.2.svn  -lgrass_gis.7.2.svn -lm  -L/usr/lib64 -lgeos
 -lgeos_c    -lm
 OBJ.x86_64-pc-linux-gnu/geos.o: In function `geos_buffer':
 mapping/grass/grass72/grass-7.2.svn_src_snapshot_2016_07_30/vector/v.buffer/geos.c:153:
 undefined reference to `Vect_read_area_geos'
 mapping/grass/grass72/grass-7.2.svn_src_snapshot_2016_07_30/vector/v.buffer/geos.c:155:
 undefined reference to `Vect_read_line_geos'
 collect2: error: ld returned 1 exit status
 ../../include/Make/Module.make:18: recipe for target
 '/home/rick/temp/newapps/apps/science/gis-
 -pc-linux-gnu/bin/v.buffer' failed
 make: *** [/home/rick/temp/newapps/apps/science/gis-
 -pc-linux-gnu/bin/v.buffer] Error 1
 --snip--
 In case this might be of any help, I installed the 03-Aug-2016 svn generic
 binary of grass7.2 and v.buffer in that installation runs fine (geos-4.3.2
 is installed on system). However, borrowing v.buffer binary from it and
 placing it into the original /usr/local/grass72/bin directory and running
 that, v.buffer output complains about undefined symbol for
 Vect_read_line_geos and Vect_read_line_geos.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3118#comment:2>
