[GRASS-dev] [GRASS GIS] #2368: Python version of r.grow does not support shrinking
GRASS GIS trac at osgeo.org
Sat Aug 6 12:24:23 PDT 2016
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:              |     Status:  new
  enhancement            |
  Priority:  minor       |  Milestone:  7.2.0
 Component:  Raster      |    Version:  svn-trunk
Resolution:              |   Keywords:  r.grow, r.grow.distance, r.buffer,
       CPU:              |  r.buffer.lowmem
  Unspecified            |   Platform:  Unspecified
Comment (by hellik):
 Replying to [comment:10 neteler]:
 > Just tested r.grow with a negative radius and the following error
 occurs:
 > # NC sample dataset
 > v.in.region box
 > v.to.rast input=box output=box use=val val=1
 > r.grow input=box output=box_shrink radius=-20.01
 > Reading raster map <box>...
 >  100%
 > Writing output raster maps...
 >  100%
 > ERROR 1: PredictorSetup:Horizontal differencing "Predictor" not
 supported with 64-bit samples
 >  100%
 > Color table for raster map <box_shrink> set to 'box'
 tested your example by
 System Info
 GRASS Version: 7.3.svn
 GRASS SVN revision: r69040
 Build date: 2016-07-29
 Build platform: x86_64-w64-mingw32
 GDAL: 2.1.0
 PROJ.4: 4.9.2
 GEOS: 3.5.0
 SQLite: 3.7.17
 Python: 2.7.5
 wxPython: 2.8.12.1
 Platform: Windows-8-6.2.9200 (OSGeo4W)
 r.grow --verbose input=rbox at user1 output=rbox_shrink2 radius=-500.1
 Lese Rasterkarte <rbox at user1> ...
 Schreibe Ausgabe-Rasterkarten...
 Color table for raster map <rbox_shrink2> set to 'rbox at user1'
 result raster is the same as the input raster, but no shrinking
 r.info map=rbox at user1
  | Map:      rbox at user1                     Date: Sat Aug 06 21:16:35 2016
  | Mapset:   user1                          Login of Creator: hkmyr
  | DataBase: D:\grassdata
  | Title:    Rasterized vector map from values
  | Timestamp: none
  |   Type of Map:  raster               Number of Categories: 1
  |   Data Type:    CELL
  |   Rows:         1350
  |   Columns:      1500
  |   Total Cells:  2025000
  |        Projection: Lambert Conformal Conic
  |            N:     228500    S:     215000   Res:    10
  |            E:     645000    W:     630000   Res:    10
  |   Range of data:    min = 1  max = 1
  |   Data Source:
  |    Vector Map: box at user1
  |    Original scale from vector map: 1:1
  |   Data Description:
  |    generated by v.to.rast
  |   Comments:
  |    v.to.rast input="box at user1" layer="1" type="point,line,area"
 output=\   |
  |    "rbox" use="val" value=1 memory=300
 (Sat Aug 06 21:22:58 2016) Befehl ausgeführt (0 Sek)
 (Sat Aug 06 21:23:06 2016)
 r.info map=rbox_shrink2 at user1
  | Map:      rbox_shrink2 at user1             Date: Sat Aug 06 21:19:58 2016
  | Title:    rbox_shrink2
  | Timestamp: none
  |   Type of Map:  raster               Number of Categories: 0
  |   Data Type:    DCELL
  |   Rows:         1350
  |   Columns:      1500
  |   Data Description:
  |    generated by r.mapcalc
  |   Comments:
  |    if(!isnull(rbox at user1), rbox at user1, if(r.grow.tmp.7272.dist <
  |    25010001, r.grow.tmp.7272.val, null()))
  |    r.grow.py "--verbose" "input=rbox at user1" "output=rbox_shrink2"
 "radius= |
  |    -500.1"
Ticket URL: <https://trac.osgeo.org/grass/ticket/2368#comment:11>
