[GRASS-dev] [SoC] GSoC: Basic cartography suite in GRASS - Week 10
Moritz Lennert
mlennert at club.worldonline.be
Mon Aug 8 08:25:11 PDT 2016
On 08/08/16 17:09, Veronica Andreo wrote:
> It works for me in the wxGUI (grass trunk r69093M).
> Did you install the add-on? It works if you also have the add-on
> installed :)
I have the addon installed in r69064.
Trying to launch it from the wxGUI console I get:
"Command 'd.legend.vect' not yet implemented in the WxGUI. Try adding it
as a command layer instead."
I display a local mapset copy of the hospitals file from the NC dataset:
d.vect map=myhospitals at user1 type=point,line,boundary,area,face
fill_color=red width=1 icon=basic/cross3
I then add d.legend.vect as a command layer without arguments, and I get
the "Rendering..." info in the map display indicating rendering half-way
through, the "operation busy"-wheel (don't know if there is an official
name for this) turning, but nothing happening. No error message in the
wx console or in the terminal.
When I display the same map in the wx0 monitor via the terminal and then
launch d.legend.vect in the same terminal I get
d.legend.vect
ERROR: No legend file defined.
GRASS_INFO_WARNING(8082,1): Unsupported command d.legend.vect.
GRASS_INFO_END(8082,1)
Moritz
> 2016-08-08 12:04 GMT-03:00 Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>>:
> On 05/08/16 04:06, Anna Petrášová wrote:
> On Mon, Aug 1, 2016 at 4:34 AM, Moritz Lennert
> <mailto:mlennert at club.worldonline.be>> wrote:
> Adam,
> On 31/07/16 20:50, Adam Laža wrote:
> Hi all,
> below is my tenth week report.
> Best regards,
> Adam
> Wiki page:
> https://trac.osgeo.org/grass/wiki/GSoC/2016/BasicCartographySuiteInGRASS
> <https://trac.osgeo.org/grass/wiki/GSoC/2016/BasicCartographySuiteInGRASS>
> Week 10, July, 25 - July, 29
> 1. What did you get done this week?
> I fixed a bug in d.legend module [1]
> I worked on d.legend.vect module. I implemented the
> vector legend for
> GUI and d.mon.
> I designed some symbols for area and line vector maps.
> 2. What do you plan on doing next week?
> I will continue work on vector legend.
> Great work on the cartography front !!
> Another idea for the vector legend: add a frequency
> histogram next to the
> legend to see how many objects are in each class. A bit like
> the histogram
> feature of the raster legend for continuous data (would be
> nice to have that
> for categorized data as well).
> Just to keep you busy ;-)
> I suggest to create an enhancement ticket for that because we won't
> get to it in this GSoC and this nice idea could get lost.
> BTW, I committed the first version of the vector legend, so you can
> test it in trunk. You still have to run:
> g.extension d.legend.vect
> I haven't been able to get it to work, neither in the wxGUI nor with
> a d.mon wx monitor. Is there a short howto somewhere ?
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-dev
> <http://lists.osgeo.org/mailman/listinfo/grass-dev>
