[GRASS-dev] [GRASS GIS] #3123: d.legend.vect: wrong handling of spaces in legend_label
GRASS GIS trac at osgeo.org
Tue Aug 9 01:07:00 PDT 2016
 Reporter:  mlennert                             |      Owner:  grass-dev@…
     Type:  defect                               |     Status:  new
 Priority:  normal                               |  Milestone:  7.0.5
Component:  Addons                               |    Version:  unspecified
 Keywords:  d.legend.vect, gsoc2016,             |        CPU:  Unspecified
  cartography                                    |
 Platform:  Unspecified                          |
 When using spaces in the legend_label parameter of d.vect, d.legend.vect
 only displays the first word before the space.
 An example with the NC dataset:
 d.vect map=hospitals at PERMANENT type=point,line,boundary,area,face width=1
 legend_label=Hôpitaux
 d.legend.vect
 'Hôpitaux' is displayed correctly.
 legend_label="Les Hôpitaux"
 d.legend.vect
 Only 'Les' is displayed in the legend.
 In the legend file, there is
 Les Hôpitaux|basic/x|5|black|200:200:200|1|point|160
 So the issue seems to be clearly with d.legend.vect.
 Another issue with white space:
 legend_label=" "
 d.legend.vect
 Now I see an 'x' as the label in the map display. In addition, if I
 repeatedly click on 'Apply' in the d.legend.vect gui, the label displayed
 cycles through a series of weird combinations of characters, always
 beginning with the 'x'. Combinations I've seen include
 xK[
 x[cc
 x[]
 x{
 I would guess this some issue with memory address handling ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3123>
