[GRASS-dev] [GRASS GIS] #3122: d.legend.vect: possibility to change text of displayed labels and select labels to show/not show
trac at osgeo.org
Tue Aug 9 05:05:38 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 7.3.0
Component: Display | Version: unspecified
Resolution: | Keywords: d.legend.vect, gsoc2016,
CPU: | cartography
Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:9 veroandreo]:
> Replying to [comment:8 lazaa]:
> [all the rest deleted]
> > It's possible using {{{input}}}/{{{output}}} parameter. After adding
all layers (boundary, rivers, bridges) you call d.legend.vect module with
parameter output
> > {{{d.legend.vect -b at=10,40 output=legend_out}}}.
> > You get file you can edit:
> > boundary|legend/area|5|139:105:20|227:227:186|3|area|8
> > rivers|legend/line|5|232:146:34|200:200:200|2|line|10837
> > bridges|basic/cross2|10|red|white|0|point|160
> > After deleting first line and saving file as e.g. ''legend_in'' you
run d.legend.vect once again with {{{input}}} parameter
> > {{{d.legend.vect -b at=10,40 input=legend_in}}} and you get legend
with only two layers altough three layers are displayed in map window.
> Yes, Anna said before that that was the way to do it currently and this
is probably useful for scripts, but maybe not very straightforward,
especially for new users or those only using GUI.
Yes, that's why I would suggest an additional flag to d.vect which if set
would mean that this vector layer should not be part of the legend. This
would then graphically translate into a checkbox in the 'legend' tab of
the d.vect GUI.
Ticket URL: <http://trac.osgeo.org/grass/ticket/3122#comment:10>
