[GRASS-dev] [GRASS GIS] #3127: r.in.wms fails
trac at osgeo.org
Wed Aug 10 02:35:00 PDT 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.3.0
Component: Raster | Version: svn-trunk
Keywords: WMTS, raster | CPU: x86-64
Platform: Linux |
taken from user ML [https://lists.osgeo.org/pipermail/grass-
user/2016-August/074653.html user ML]
r.in.wms --verbose
url=https://www.basemap.at/wmts/1.0.0/WMTSCapabilities.xml output=test
layers=bmapgrau srs=3857 driver=WMTS_GRASS
Downloading data from WMS server...
WARNING: no switch
Fetching 56 tiles with 256 x 256 pixel size per tile...
File "/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-
linux-gnu/scripts/r.in.wms", line 236, in <module>
sys.exit(main())
linux-gnu/scripts/r.in.wms", line 222, in main
fetched_map = wms.GetMap(options, flags)
linux-gnu/etc/r.in.wms/wms_base.py", line 210, in GetMap
self.temp_map = self._download()
linux-gnu/etc/r.in.wms/wms_drv.py", line 205, in _download
tile_dataset.GetRasterBand(1).DataType)
AttributeError: 'NoneType' object has no attribute
'DataType'
r.in.wms --verbose
layers=bmapgrau srs=3857 driver=WMS_GDAL
ERROR 1: GDALWMS: The server returned unknown exception.
ERROR 1: /home/bugs/grassdata/loc_epsg3857/rastadata/.tmp/na
da/3422.1, band 1: IReadBlock failed at X offset 0, Y offset
0
ERROR 1: GetBlockRef failed at X block offset 0, Y block
offset 0
ERROR: Incorrect WMS query
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r69110
Build date: 2016-08-09
Build platform: x86_64-pc-linux-gnu
GDAL: 2.1.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.8.7.1
Python: 2.7.9
wxPython: 3.0.1.1
Platform: Linux-3.16.0-4-amd64-x86_64-with-debian-8.5
g.region -p
projection: 99 (WGS 84 / Pseudo-Mercator)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 5961400
south: 5930120
west: 1401500
east: 1407550
nsres: 10
ewres: 10
rows: 3128
cols: 605
cells: 1892440
Ticket URL: <http://trac.osgeo.org/grass/ticket/3127>
