[GRASS-dev] Errored: GRASS-GIS/grass-ci#1438 (master - 5442e14)
Vaclav Petras wenzeslaus at gmail.com
Wed Aug 10 13:45:10 PDT 2016
On Wed, Aug 10, 2016 at 3:46 PM, Travis CI <builds at travis-ci.org> wrote:
> *System message:*
> We are seeing build failures due to new sudo-enabled Precise and Trusty
> images. See more details here
> <https://www.traviscistatus.com/incidents/11hp8bhkrkn7>. Thank you for
> your enduring patience.
The issue is on their side - they attach the above message and make the
error gray instead of red (other hint is the long build time).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160810/29ae42dd/attachment.html>
