[GRASS-dev] [GRASS GIS] #3128: r.tile not working with overlap
trac at osgeo.org
Thu Aug 11 02:43:08 PDT 2016
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Raster | Version: 7.0.4
Keywords: r.tile | CPU: Unspecified
Platform: Linux |
See thread here: https://lists.osgeo.org/pipermail/grass-
user/2016-August/074657.html
Problems:
- Specifying a overlap value, it gives: ERROR: Illegal latitude for North
- Geodesic support to work in lat lon seems missing. Note that it is
probably the most common case to work in lat lon when dealing with large
files that need to be tiled.
- Please add example in the manual page
Enhancement:
- It would be nice to have the possibility to specify different overlap
values for rows and cols, if for example overlap is desired only along
columns
Thank you!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3128>
