[GRASS-dev] [GRASS GIS] #3119: r.out., gdal -c should not write Metadata: COLOR_TABLE_RULE_RGB
trac at osgeo.org
Thu Aug 11 12:25:40 PDT 2016
#3119: r.out.,gdal -c should not write Metadata: COLOR_TABLE_RULE_RGB
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3119 neteler]:
> At time, when suppressing the color table export (eg when writing out
in GeoTIFF format) with
> r.out.gdal -c ...
> still the metadata are written:
> Metadata:
> COLOR_TABLE_RULES_COUNT=5
> COLOR_TABLE_RULE_RGB_0=1.000000e+00 1.122440e+04 255 255 0 0 255 0
> COLOR_TABLE_RULE_RGB_1=1.122440e+04 2.244780e+04 0 255 0 0 255 255
> COLOR_TABLE_RULE_RGB_2=2.244780e+04 3.367120e+04 0 255 255 0 0 255
> COLOR_TABLE_RULE_RGB_3=3.367120e+04 4.489460e+04 0 0 255 255 0 255
> COLOR_TABLE_RULE_RGB_4=4.489460e+04 5.611800e+04 255 0 255 255 0 0
> The code is here:
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.out.gdal/export_band.c#L315
> Perhaps the if condition here should also consider
"suppress_main_colortable"?
The new 'm' flag suppresses writing out GRASS color rules to metadata in
order to enhance compatibility with other GIS software not using GDAL
(r69128-30 for trunk, relbr72, relbr70).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3119#comment:1>
